LMS 3.2 - Syslog Collector won't subscribe
eidumsigfrid
The Syslog Collector won't subscribe to itself as it states "Unable to resurrect connection to a subscriber". The syslog collector status GUI is blank with no collectors listed. I have tried subscribing to the hostname however it states it is not valid.
I have restarted daemons in an attempt to recover.
Also ran the syslogconf.pl script again. No luck.
SyslogConf.log
SyslogCollector.log
SyslogAnalyzerUI.log
Collector.properties are attached.
Joe Clarke
SyslogCollector is failing to startup because is cannot read /var/log/syslog_info.  Check to make sure that this file is readable by casuser.  Make sure that all the directories leading up to this file (/var and /var/log) have 0755 permissions.
Joe Clarke
Awesome. Thanks mate. Fixed.
I thought I checked that already but must have overlooked.
This was working fine in the past I suspect logrot.pl is defaulting the syslog_info file to owner of root. Is there anyway to retain ownership of the file to casuser for syslog_info ?
Logrot.pl will not change ownership of the file because logrot doesn't change the inode (it truncates the file in place).  If you're using logadm, on the other hand, it can change the inode unless you run it with the -c option.
How do I check that the file is readable by casuser and that all the directories leading up to this file (/var and /var/log) have 0755 permissions? How do I set 0755 permission? Sorry for my ignorance.
