LMS 3.2 - unknow SNMP error for Cisco XR12406
danny2125
Hi ,
I got a RME job alert which describes SNMP RW community verification failure in Device Credentials Verification for Cisco XR12406 router, I have double checked on the credential configured in LMS and it is correct.
The configuration that i tried in XR12406:
snmp-server community T3lBruRW RW <acl>   ---> not working
snmp-server community T3lBruRW RW SystemOwner <acl> ---> not working
Anyone can help!!!
Nael Mohammad
Level 5
Level 5
Use device center and attempt to do an snmpwalk and post the results using this OID "1.3.6.1.4.1.9.1.388".
Thanks for reply, the result :
The following is a SNMP walk of device 61.6.255.233 starting from .1.3.6.1.4.1.9.1.388
SNMP Walk Output
CISCO-PRODUCTS-MIB::cisco12406 = No Such Object available on this agent at this OID
Post the show ver output so I can do a recreate in the lab against that device.
Hi Nael, here it is:
#sh ver
Sun Nov 28 15:43:14.648 BNT
Cisco IOS XR Software, Version 3.8.2[00]
Copyright (c) 2009 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 12.0(20060713:113510) [sunnaik-31s5th 1.16dev(0.1)] DEVELOPMENT SOFTWARE
Copyright (c) 1994-2006 by cisco Systems,  Inc.
CRTH uptime is 8 weeks, 2 days, 20 hours, 45 minutes
System image file is "disk0:c12k-os-mbi-3.8.2/mbiprp-rp.vm"
cisco 12406/PRP (7457) processor with 2097152K bytes of memory.
7457 processor at 1266Mhz, Revision 1.2
3 Cisco 12000 Series SPA Interface Processor-601/501/401
2 Cisco 12000 Series Performance Route Processors
6 Management Ethernet
12 PLIM_QOS
4 TenGigE
15 GigabitEthernet/IEEE 802.3 interface(s)
1018k bytes of non-volatile configuration memory.
1998M bytes of compact flash card.
2048800k bytes of disk0: (Sector size 512 bytes).
65536k bytes of Flash internal SIMM (Sector size 256k).
Boot device on node 0/0/CPU0 is mem:
Package active on node 0/0/CPU0:
c12k-k9sec, V 3.8.2[00], Cisco Systems, at disk0:c12k-k9sec-3.8.2
    Built on Wed Oct 28 19:00:47 BNT 2009
    By edde-bld1 in /auto/srcarchive3/production/3.8.2/c12k/workspace for c4.2.1-p0
c12k-lc, V 3.8.2[00], Cisco Systems, at disk0:c12k-lc-3.8.2
    Built on Wed Oct 28 16:27:50 BNT 2009
c12k-fwdg, V 3.8.2[00], Cisco Systems, at disk0:c12k-fwdg-3.8.2
    Built on Wed Oct 28 16:26:44 BNT 2009
c12k-admin, V 3.8.2[00], Cisco Systems, at disk0:c12k-admin-3.8.2
    Built on Wed Oct 28 16:25:55 BNT 2009
c12k-base, V 3.8.2[00], Cisco Systems, at disk0:c12k-base-3.8.2
    Built on Wed Oct 28 16:24:15 BNT 2009
c12k-os-mbi, V 3.8.2[00], Cisco Systems, at disk0:c12k-os-mbi-3.8.2
    Built on Wed Oct 28 16:19:12 BNT 2009
Boot device on node 0/1/CPU0 is mem:
Package active on node 0/1/CPU0:
Boot device on node 0/2/CPU0 is mem:
Package active on node 0/2/CPU0:
Configuration register on node 0/4/CPU0 is 0x2102
Boot device on node 0/4/CPU0 is disk0:
Package active on node 0/4/CPU0:
c12k-rout-3.8.2.CSCti62211, V 1.0.0[SMU], Cisco Systems, at disk0:c12k-rout-3.8.2.CSCti62211-1.0.0
    Built on Sat Aug 28 15:36:26 BNT 2010
    By edde-bld1 in /vws/afz/builds/smu_r38x_3_8_2/workspace for c4.2.1-p0
c12k-rout, V 3.8.2[00], Cisco Systems, at disk0:c12k-rout-3.8.2
    Built on Wed Oct 28 16:28:36 BNT 2009
Configuration register on node 0/5/CPU0 is 0x2102
Boot device on node 0/5/CPU0 is disk0:
Package active on node 0/5/CPU0:
