LMS 3.2
laptev.valery
I cannot launch Topology Services in Campus Manger.
When I start it it shows messge, that i need to restart browser.
I used to restart my computer, brouser, but I see same message:
Any body know, how to fix it???
dosic
Level 3
Level 3
Valery,
may be I'm wrong but it's a java problem.
This helps me:
start->control panel -> java -> advanced (right corner).
settings - > java console - > show console.
Apply and try again,
I tryed.
Sorry, that didnt work.
hi mate,
I had same problem, and found this topic that helped me.
J.C. explained everything quite goood, I'm sure that it'll help U too.
https://supportforums.cisco.com/message/2006334#2006334
I have try it on my computer, still not work on my computer. On other it works just fine! works on server side.
now i have trobble whith my ASDM(615)
java version is not good for ASDM and LMS at same time. And i can not instal 2 versions at the same time on 1 OS(windows 7).
