LMS 3.2
Lasse Nylander
I need some help solving this problem!
I have one server where LMS is not coming up. Its running Solaris.
stdout says: "TomcatMonitor Tomcat is not ready, it's coming up connection refused"
I have tried to regenerate ssl cert. but it did'nt solve the problem.
pdshow and stdout is attatched.
Lasse
Robert Pavone
Level 5
Level 5
Lasse,
It a permissions issue somewhere.  Is this a "slave" LMS server?  Make sure the system identity user (defined under Common Services) is matching across the servers.  Are you integrated with ACS?
Definitely looks like an underlying permissions issue.
rob
Robert Pavone
Level 5
Level 5
Lasse,
rob
Hi Rob
Yes it's a "slave" and we use TACACS+ and ACS.
