LMS 3.2
thomasandy32
Hello clarke,
I have LMS 3.2 product,But i have all HP switches,will it be worth to discover HP switches in LMS,and what feature's will be available for HP switches from LMS.
No, software and config management cannot be done.  You can bring up Device Center, but the device will only have very generic options (e.g. ping, traceroute, SNMP Walk, etc.).
5 Replies 5
Joe Clarke
LMS is designed to manage Cisco devices.  You will not get much value for non-Cisco equipment.  RME will be able to do some basic MIB-II inventory collection, and you can setup pollers in the Health and Utilization Monitor add-on, but that's about it.  Those HP devices will also count against your license, so it's best to not add them to the various LMS applications.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Hello Clarke,
RME will be able to do some basic MIB-II inventory collection ????
what is MIB-II inventory collection??
I don't have a HUM included in that it is not extension only the base model.
Thanks for kind reply.
MIB-II collection is the system branch and the ifTable.  You will not get asset details like serial numbers, memory information, file system info, etc.  Yes, HUM is an add-on which requires a separate license.
Thanks clarke,
Can i  do software deployment,config deployment,use of device centre,vlan configurtion ??????    OR just what u have mentioned above.
Thanks once again for ur prompt reply
