LMS 4.0 and ASA SSM-10 SSH problem
Darko Gmajner
Hello. After succesfull adding SSM-10 IPS modul with primary credential (username/password) and SNMP V2 credentials (Both strings are correct)  to LMS 4.0, I am not able to succesfully finish the Device Credentials Verification Job and collecting the configuration (Sync Archive). The result is:
Read Community : Ok, Read Write Community : Wrong Credentials, SSH : Incorrect. The same username and password I use to connect to IPS with PuTTY using SSH conection type and/or  through the Internet Explorer and in the both cases the connection is succesfull. I try this from the same IP address (computer) where is installed LMS. What did I missed ?
Michel Hegeraat
Level 7
Level 7
If you are sure that the SNMP readwrite community string is correct  (how did you establish this?) then try to do an SMNP read with it
goto CSCOpx/objects/jt/bin
Check the executables there to do the test
Cheers,
Michel
