Showing results forĀ
Search instead forĀ
Did you mean:Ā
LMS 4.0 Configuration issue
chs.gov.sa
hi all,
i installed lms 4.0 on win server 2008 enterprise edition  ( ip address 10.10.100.50 )but after installion i enabled snmp v2c on cisco switches by the following commands :-
snmp-server host 10.10.100.50 version 2c private
snmp-server host 10.10.100.50 version 2c public
snmp-server community public RO
snmp-server community private rw
access-list 10  permit 10.10.100.50 0.0.0.0
snmp-server community public ro 10
snmp-server community private rw 10
snmp-server enable traps
ip rcmd rcp-enable
ip rcmd remote-host CHS 10.10.100.50 CHS enable
ip rcmd remote-username CHS
then i start the descovering from -- admin --- dicovery settings --- seed ( contains all switches ips ) --- i chosed snmp v c2 --- then the target was all ip address of switches --- then discoveing by cdp
the result was all cisco switches added to DCR
one of the devices status was unknown ... i dont know why ??
when i tried to create vlan by lms server to the core switch
i faced the following error
An error occured while performing SNMP operation.
Action:Examine and save the server log file and report the error to the product administrator for further action.
and what about mdf ??
how i can configure that and is it necessary for fault report .
i need very well help
thanks all
Joe Clarke
MDF isn't something that needs to be configured.  It is an architectural component of LMS.  The most likely reason you cannot create VLANs is that LMS does not know what your read-write community string is.  Discovery only populates DCR with the read-only string.  Go to Inventory > Add/Import/Manage Devices and edit the credentials for your switches.  Add the proper read-write community string, and then you should be able to configure the VLANs.
