mib - counter - ipv6 neighbors
imgiles
I need to create a graph exactly like this one for my boss:
http://http://cisco-live6.com/munin/ipv6noc/ipv6noc/net_neighbors.html
I need a mib that shows the total number of ipv6 neighbors.
I can't walk a table to get the number because it consumes too much CPU.
I need an accumulated count like the ones shown by "show ipv6 neighbor statistics"
Is there any such mib, if not will there be one in the future?
My switches are 6509's and have the following software: 12.2(33)SXH3 and 12.2(33)SXI7
I have looked extensively, but had no luck.
Your help would be greatly appreciated.
Joe Clarke
There isn't one objects that will tell you this, but if you walk cInetNetToMediaPhysAddress and count the entries, that will tell you the number of neighbors.  On newer versions of IOS, you may need to walk ipNetToPhysicalPhysAddress.  But the same thing applies.  Count the number of ipv6 entries returned to get your total number of neighbors.
