LMS 4.0 - Fan Fault on Cisco 2960-8TC-L switch
Roland Theisen
I am using the CiscoWorks LAN Management Solution (LMS) Version 4.0 to monitor our 150 Cisco Switches. In the network we have also some Cisco Catalyst 2960 8-port switches (Model: WS-C2960-8TC-L; SW version: 12.2(35)SE) and regularly I get the following notification in the Fault Monitor:
Event_Description: StateNotNormal
Device IP: IP_Address
Device Type: Switches and Hubs
Component Class: Fan
Component Event Code: 1088
Event Category: Environment
Event Source: DFM
Status: CRITICAL
As far as I know, the 2960-8TC-L switches have no build-in Fan. Or am I wrong?
Can anybody tell me what I should do with this notification? Ignore it? Or is there a problem with my switch?
Thanks a lot in advanced.
Best regards,
Marc Hoffmann
these switches do not have a fan ...
Compact Switches
Cisco Catalyst 2960-8TC-L
8 Ethernet 10/100 ports; compact size with no fan
1 dual-purpose port (10/100/1000 or SFP)
Cisco Catalyst 2960PD-8TT-L
1 10/100/1000 PoE input port
Cisco Catalyst 2960G-8TC-L
7 Ethernet 10/100/1000 ports; compact size with no fan
DFM uses the CISCO-STACK-MIB for the fan status; You can poll 1.3.6.1.4.1.9.5.1.2.9 to see what the switch returns. The values can be interpreted using this list from http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=chassisFanStatus
1 : other
2 : ok
3 : minorFault
4 : majorFault
The reason for this could be BugID CSCsh15007 for IOS 12.2(35)SE; It is fixed in 12.2(35)SE1;
For a solution, you need to upgrade the IOS.
Nael Mohammad
Level 5
Level 5
2960-8TC-L does have a fan according to the product page.
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Post the "show environment status" output and compare it to LMS faults.
Compact Switches
1 : other
2 : ok
3 : minorFault
4 : majorFault
