02-23-2012 01:29 AM
I would like to know if there's a way to show CurrentUtilization percentage within the messages generated by the Fault Management Module in LMS 4.0
EVENT ID = 00008Z1
TIME = S
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = switch
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = HighUtilization::Component=PORT-switch/11150 [Gi3/0/50] [---> TRUNK ];ComponentClass=Port;ComponentEventCode=1057;TrafficRate=5.2261432E7 BYPS;DuplexMode=FULLDUPLEX;UtilizationThreshold=40;MaxSpeed=1000000000;Type
NOTIFICATION ORIGINATOR = Fault Management Module
As you can see above CurrentUtilization percentage is not shown in Event Description section.
Could someone help?
Thank you!
Massimiliano.
02-23-2012 06:45 AM
To my knowledge nothing can be configured here.
You have to take traffic rate and max speed and do the calculation yourself
FAD! functioning as designed
Cheers,
Michel
02-23-2012 07:20 AM
Hi Michel,
thanks for your reply. It was my suspicious!
Maybe someone else can enlighten us.
Or at least let us know if the CurrentUtilization percentage counter will come with future release/patch.
Ciao,
Massimiliano
