Showing results forĀ
Search instead forĀ
Did you mean:Ā
LMS 4.0 IP Address
dominoforever
I changed the IP address and restarted my LMS server but some features don't work. I can do a system backup for example, discovery too but not Sync Archive or Manage Device State.
When I try, I have a message which say : DCMA0022: No device selected. Select one or more devices to continue.
Do I forget something?
Kind regards
8 Replies 8
AFROJ AHMAD
Hi ,
You have changed  JUST the IP addreess or you have changed the HOST NAME too ?
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I just change IP Address, hostname is always the same.
There is BUG  for the same issue :
lms 4.0:Issue in Sync Archive Job page
CSCte83028
seems to be fixed in 4.0 as per the BUG details
If you have a good backup try restoring it..
Thanks-
Afroz
Also did you update any device packges ??
I cannot see yout link.
I don't see any switchs in Device Group Management or in Device Management.
In Inventory -> CiscoView -> no switch but if I make a search the switch is displayed.
No updates were made.
try and reboot the server again and see  it makes any differenece
I shutdown the server and started it, then everything works fine...
Thanks for your help Afroj!
great
Kindly mark it resolved ..
