LMS 4.0 : lost link connection between devices topology view ???
minh pham
Hi all,
I'm using LMS 4.0, after I auto  discovery device, I can see all of devices on my network but I cannot  view the links connect between the ASR 9000 and Catalyst 6509. I've just  checked cdp neighbor on these devices, I can see the full of neighbors.
I  attach 2 file, with the visio topology and the topology view  on LMS , and I'm 100% sure about the connections between these  devices are used. I try to re-discovery many times but it not work  correctly.
how can i fix the problem on LMS ?
thanks,
minh pham
No-one reply my issue. please, I need some advices to fix this problem.
minh pham
Hi all,
have any ideas about this ??? I re-discovery and manual add device, it can not show the link between ASR and Catlyst 6509. Link connect between ASR and 6509 use port-channel.
