02-03-2014 08:18 AM
I have LMS v4.0 installed and was it working fine (Windows Server 2008R2 Std).
However, I had call to reboot the physical server last week (it had been up for over 6 months) and I am now having problems with most options under the Inventory menu.
I have attached screenshots of the errors I am getting and the end of the DCRServer.log file which indicates that the DCR server has started ok.
I have disabled the DHCP Client service as I saw in another post that this has been known to cause the issue I am seeing, but that has not made any difference.
I have exhausted everything I can think of and am hoping that someone on here can give me some advice or ideas as to where to look next.
Steve
02-03-2014 08:24 AM
Hi Steve,
share the output of pdshow
and below files
md.properties (NMSROOT\CSCOpx\lib\classpath)
ctm_config.txt file from NMSROOT\CSCOpx\MDC\tomcat\lib and
NMSROOT\CSCOpx\MDC\tomcat\shared\lib
and last 200 lines of syslog.log
Thanks-
Afroz
02-03-2014 08:46 AM
Hi Afroz, thanks for the super fast response
Please find everything attatched.
I do not have a ctm_config.txt file in NMSROOT\CSCOpx\MDC\tomcat\lib, the one attached is from NMSROOT\CSCOpx\MDC\tomcat\shared\lib.
The syslog file is over 1.6Gb so it may take me a while to open that one - will post it as soon as I have managed to extract the last 200 lines.
02-03-2014 05:06 PM
Hi Steve,
Some Major processes are down.
Process= EssentialsDM
State = Administrator has shut down this server
Process= ConfigMgmtServer
Process= CTMJrmServer
Process= ANIServer
Follow the below steps:
1.shutdown daemon manager(net stop crmdmgtd)
2.then remove ctmregistry* from NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib.
3. Regenrate the SSLcertificate :
3.1. Remove the following certificate files from (NMSROOT/MDC/Apache/conf/ssl)
a. server.crt
b. server.key
c. server.pk8
3.2 Disable SSL: NMSROOT/bin/perl "NMSROOT/MDC/Apache/ConfigSSL.pl" -disable
3.3. Enable SSL to generate certificate:
NMSROOT/bin/perl "NMSROOT/MDC/Apache/ConfigSSL.pl" -enable
4. start the daemon manager (net start crmdmgtd)
Also make sure the casuser is a part of ADMINISTRATOR Group.
one last thing , Reset the casuser as well.
NMSROOt/CSCOpx/setup/support>resetCasuser.exe
Hope it will help.
Thanks-
Afroz
02-04-2014 02:11 AM
Hi Afroj,
Thanks for that, I have followed the instructions you posted and a pdshow now shows all the processess listed in your reply above as all running ok.
However, now I cannot even login. After entering the correct username/password I get:
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I therefore disabled the SSL Cert again ( NMSROOT/bin/perl "NMSROOT/MDC/Apache/ConfigSSL.pl" -disable) and restarted the Daemon which now allows me to login ok.
However I am now back to the original problem of most options in the Inventory menu saying "Error in communicating with DCR Server". A pdshow shows all the services you referred to originally are all running ok.
02-04-2014 02:15 AM
Hi steve ,
try with port 443.
thanks-
02-04-2014 02:21 AM
Afroj,
Just to clarify...
I currently have a shortcut (on the LMS server) that fires up a browser with a URL of http://servername:1741
Should I re-enable the SSL (NMSROOT/bin/perl "NMSROOT/MDC/Apache/ConfigSSL.pl" -enable), restart the Daemon and then attempt to browse to https://servername ???
Steve
02-04-2014 02:30 AM
can you try above and see how it works
02-04-2014 02:51 AM
Hi Afroj,
I re-enabled the SSL, stopped/started the Daemon and browsed to http://servername:443
I just get a totally blank white page (no errors).
Using the original shortcut (http & port 1741), I get the "There is a problem with this website's security certificate." (which I have always had), continue and enter the logon credentials, it then throws up the Forbidden error I posted above.
02-04-2014 02:52 AM
Steve,
let it be disabled Only.
DO not delete any files just run the -disable command and login again.
02-04-2014 03:30 AM
Afroj,
Have done the -disable and restarted Daemon.
Browsing to http://servername:443 just gives totally blank white page.
Browsing to http://servername:1741 allows me to login (after getting warning about certificate which is normal), but I have the original error within the Inventory menu - Error in communicating with DCR Server.
Current pdshow output attached.
02-04-2014 04:18 AM
Processses are fine ..
copy the the ctm_config.txt file to all the location. we need to have this file on all the three location.
/NMSROOT/MDC/tomcat/shared/lib/ /NMSROOT/MDC/tomcat/webapps/cwhp/WEB-INF/lib/ /NMSROOT/MDC/tomcat/lib/
One more thing add the LMS server hostname and ip address in the hosts file C:\Windows\System32\drivers\etc
Thanks-
Afroz
02-04-2014 04:31 AM
I dont have a /NMSROOT/MDC/tomcat/lib/ directory.
Where should I copy the ctm_config.txt file from, there is already one in the other two directories.
Have added 4 entries to the hosts file:
server name in lowercase
server name in uppercase
localhost
and FQDN servername in lowercase
02-04-2014 05:55 AM
can you share the error.log and apache.log from NMSROOT/CSCOpx/MDC/apache/logs
Stdout.log from NMSROOT/CSCOpx/MDC/tomcat/logs
Thanks-
02-04-2014 06:38 AM
Hi Afroj,
I dont have a apache.log file.
Have attached the error.log & stdout.log as requested.
For some reason , I dont think it is starting properly now - I do not get any emails of down devices when it starts up which I have always had before, and the processes you references in your first response are sat at 'Never started' again.
Couple of things:
Should the hostname when generating the certificate be the FQDN or not (I regenerated WITHOUT as I found another post alluding to this)
Should the hosts file point all the variations of serername to the actual IP or the 127.0.0.1 loopback?
I also notice that on the Monitor-Dashboards-Monitoring screen I get th attached error.
Steve
