03-05-2012 02:41 AM
I am trying to setup syslog server on LMS 4.0.
Everything seems to be working fine but I have a lot of stragne logs in my syslog.log file.
Every single day I receive logs like :
Mar 05 09:31:03 127.0.0.1 100: <30> dmgt[1136]: 3007(I):Started application(1015) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\struts.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmplr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xstream-1.1.1.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xpp3.jar;MDC\tomcat\webapps\up
Mar 05 09:31:03 127.0.0.1 100: <30> dmgt[1136]: 3009(I):Application "1018" registered.
Mar 05 09:31:03 127.0.0.1 100: <30> dmgt[1136]: 3007(I):Started application(1018) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ags.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xdi.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\deviceselector.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\mibmgr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\W
Mar 05 09:31:36 127.0.0.1 100: <30> dmgt[1136]: 3021(I):Died method called for process (1018, pid=6600).
Mar 05 09:31:36 127.0.0.1 100: <30> dmgt[1136]: 3011(I):Application "1018" unregistered.
Mar 05 09:31:36 127.0.0.1 100: <30> dmgt[1136]: 3021(I):Died method called for process (1015, pid=5632).
Mar 05 09:31:36 127.0.0.1 100: <30> dmgt[1136]: 3011(I):Application "1015" unregistered.
Mar 05 10:48:01 127.0.0.1 100: <30> dmgt[1136]: 3021(I):Died method called for process (UTMajorAcquisition, pid=10388).
Mar 05 08:31:03 127.0.0.1 100: <30> dmgt[1136]: 3009(I):Application "1015" registered.
Mar 05 08:31:03 127.0.0.1 100: <30> dmgt[1136]: 3007(I):Started application(1015) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\struts.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmplr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xstream-1.1.1.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xpp3.jar;MDC\tomcat\webapps\up
Mar 05 08:31:03 127.0.0.1 100: <30> dmgt[1136]: 3009(I):Application "1018" registered.
Mar 05 08:31:03 127.0.0.1 100: <30> dmgt[1136]: 3007(I):Started application(1018) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ags.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xdi.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\deviceselector.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\mibmgr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\W
Mar 05 08:31:39 127.0.0.1 100: <30> dmgt[1136]: 3021(I):Died method called for process (1015, pid=7600).
Mar 05 08:31:39 127.0.0.1 100: <30> dmgt[1136]: 3011(I):Application "1015" unregistered.
Mar 05 08:31:39 127.0.0.1 100: <30> dmgt[1136]: 3021(I):Died method called for process (1018, pid=6596).
Mar 05 08:31:39 127.0.0.1 100: <30> dmgt[1136]: 3011(I):Application "1018" unregistered.
I dont want to get any logs from 127.0.0.1. Is it possible to filter out logs from server ?
Thanks and best regars.
Solved! Go to Solution.
03-05-2012 02:50 AM
I don't think you can easily stop LMS from logging its own starting and stopping of processes.
Why does this bother you? It doesn't appear in you reports
Cheers,
Michel
03-05-2012 02:50 AM
Cheers,
Michel
03-05-2012 03:15 AM
You're right but it's little annoying that 3/4 of my log file are filled by some unless stuff.
03-05-2012 03:25 AM
unless* = unusefull
sorry my mistake
