LMS 4.0 syslog problem
I am trying to setup syslog server on LMS 4.0.
Everything seems to be working fine but I have a lot of stragne logs in my syslog.log file.
Every single day I receive logs like :
Mar 05 09:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3007(I):Started application(1015) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\struts.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmplr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xstream-1.1.1.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xpp3.jar;MDC\tomcat\webapps\up
Mar 05 09:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3009(I):Application "1018" registered.
Mar 05 09:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3007(I):Started application(1018) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ags.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xdi.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\deviceselector.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\mibmgr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\W
Mar 05 09:31:36 127.0.0.1 100: <30>   dmgt[1136]: 3021(I):Died method called for process (1018, pid=6600).
Mar 05 09:31:36 127.0.0.1 100: <30>   dmgt[1136]: 3011(I):Application "1018" unregistered.
Mar 05 09:31:36 127.0.0.1 100: <30>   dmgt[1136]: 3021(I):Died method called for process (1015, pid=5632).
Mar 05 09:31:36 127.0.0.1 100: <30>   dmgt[1136]: 3011(I):Application "1015" unregistered.
Mar 05 10:48:01 127.0.0.1 100: <30>   dmgt[1136]: 3021(I):Died method called for process (UTMajorAcquisition, pid=10388).
Mar 05 08:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3009(I):Application "1015" registered.
Mar 05 08:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3007(I):Started application(1015) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\struts.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmplr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xstream-1.1.1.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xpp3.jar;MDC\tomcat\webapps\up
Mar 05 08:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3009(I):Application "1018" registered.
Mar 05 08:31:03 127.0.0.1 100: <30>   dmgt[1136]: 3007(I):Started application(1018) "e:\CSCOpx\bin\cwjava.exe -cw:jre lib/jre -cp e:\CSCOpx\MDC\tomcat\shared\lib\MICE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar;e:\CSCOpx\MDC\tomcat\shared\lib\jdom.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xalan.jar;e:\CSCOpx\MDC\tomcat\shared\lib\xerces.jar;e:\CSCOpx\MDC\tomcat\common\lib\servlet.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar;e:\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar;e:\CSCOpx\lib\classpath;e:\CSCOpx\www\classpath;www\classpath\vbjorb.jar;MDC\tomcat\webapps\upm\WEB-INF\classes;lib\jre\lib\endorsed\jacorb.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\jep-3.2.0.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ags.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\xdi.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\deviceselector.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\mibmgr.jar;MDC\tomcat\webapps\upm\WEB-INF\lib\upmcmn.jar;MDC\tomcat\webapps\upm\W
Mar 05 08:31:39 127.0.0.1 100: <30>   dmgt[1136]: 3021(I):Died method called for process (1015, pid=7600).
Mar 05 08:31:39 127.0.0.1 100: <30>   dmgt[1136]: 3011(I):Application "1015" unregistered.
Mar 05 08:31:39 127.0.0.1 100: <30>   dmgt[1136]: 3021(I):Died method called for process (1018, pid=6596).
Mar 05 08:31:39 127.0.0.1 100: <30>   dmgt[1136]: 3011(I):Application "1018" unregistered.
I dont want to get any logs from 127.0.0.1. Is it possible to filter out logs from server ?
Thanks and best regars.
Michel Hegeraat
Level 7
Level 7
I don't think you can easily stop LMS from logging its own starting and stopping of processes.
Why does this bother you? It doesn't appear in you reports
Cheers,
Michel
Michel Hegeraat
Level 7
Level 7
Cheers,
Michel
You're right but it's little annoying that 3/4 of my log file are filled by some unless stuff.
unless* = unusefull
sorry my mistake
