LMS 4.1 : Create other admin users
jul.delima
I want to create personal login for the administrators in order they have the same rights as the user "admin" (I want to track them with the ACS later, but now the login method is local). I created an user and set the authorization to "Full Authorization". But when I logged with this user, I do not have the same right as the admin user. For example the new user cannot doing a manual backup, manage the license or the authentication... I tried to select the Super Admin Role (when I check the role, I can see that these options are available for this role) but I have the same problem.
Do you know if it is possible to create several user with exactly the same rights as the default "admin" user ?
Thanks in advance
Julian de Lima
jul.delima
It's ok I resolve it. It's because I logged the first time without a local user but directly with through an ACS with Tacacs. The profile was created without any roles. Then when I changed it was not possible to change back. Now I created a fresh new user with a role and it is working fine.
Julian
