Configuration copy to TFTP Auto
I am using multiple cisco 2811, 3745 routers and 2950,3550 switches if I need to copy  running configuration I have to go to each device and say copy run tftp: <address>
Is here any way that automatically by schedule one a week or a month configuration copy from all devices to tftp server?
Tamim
yjdabear
If these devices are running an IOS supporting the "archive" command, you can schedule it weekly as follows (some of the settings are optional):
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080120f48.shtml
archive
log config
record rc
logging enable logging size 50 notify syslog contenttype plaintext
hidekeys
path tftp://yourTFTPserver/path/$h__$t.cfg
ftp://IP.IP.IP.IP/path/$h__$t.cfgmaximum 12 time-period 10080 write-memory
I think this command you send me is for getting configuration file from TFTP server to Router, but I am looking for something that copy configuration from router to tftp server.
By the way I did same configuration as you said. But I got error.
archive
  log config
   logging enable
   logging size 50
   notify syslog
   hidekeys
  path tftp://10.10.10.2/$h_$t.cfg
  write-memory
  time-period 2
Here result after I said wr
TEL_OFFICE#wr
Building configuration...
[OK]
TFTP: error code 1 received - 20577
%Error opening tftp://10.10.10.2/TEL_OFFICE_-Jan-12-07:57:55.747.cfg-1 (No such file or directory)
If I do through command it is working.
TEL_OFFICE#copy run tftp:
Address or name of remote host []? 10.10.10.2
Destination filename [el_office-confg]?
1095 bytes copied in 0.400 secs (2738 bytes/sec)
