ā02-28-2012 05:39 AM
Hi!
The new LMS 4.1 has brand new GUI ! :-(
Our question:
How can i control the what kind of devices are be asked by fault management.
Now i found that Fault monitoring may be enabel/disable for all devices under "getting started/device management/device allocation setting"!
I would like to enable the Fault management only few devices ( for example 6500 etc. )
In the old LMS ths function was in DFM device management.
Solved! Go to Solution.
ā02-28-2012 10:07 AM
The feature where you could allocate per application what devices you would manage has be dropped.
Now if you decide a device is managed it is managed in all active applications.
Cheers,
Michel
Cheers,
Michel
ā02-28-2012 11:40 PM
Very thanks.
I think some features may be dropped and the new GUI is not logical !
