LMS 4.1 - huge upm.db
s.leyer
Hi All,
From one day to the next our UPM database (upm.db) has blown up from 4 Gb to 35 Gb.
Data purging didn't reduce the size of the db.
What happened ? And how can I compact the db again ?
Thank you for your suggestions.
ngoldwat
Level 4
Level 4
You can reinitialize the database if you do not have a requirement to retain the data.
This will delete the contents of the entire database including all polled data, poller and threshold configurations.
1.  Stop the Ciscoworks daemons (ie 'net stop crmdmgtd')
2.  Take a backup of LMS and HUM
From a command line,
3.  cd $NMSROOT\bin (where $NMSROOT is the location of your installation)
4.  perl dbRestoreOrig.pl dsn=upm dmprefix=UPM
5.  Restart the daemons (ie 'net start crmdmgtd')
6.  Wait 20 minutes before logging back on to LMS
If you want to preserve the data:
1.  Verify you have at least 2x the size of the upm.db free on the drive.
2.  Set the purge schedule to daily for purging all the old data.
3.  Run a purge job & wait for the purge job to complete.
4.  Stop the Ciscoworks daemons (ie 'net stop crmdmgtd')
5.  Take a backup of LMS and HUM
6.  Rebuild the database.
6.1  cd $NMSROOT\databases\upm
6.2  dbunload -c  "dbf=upm.db;uid=dba;pwd=" -ar
Note: replace with your password.
7.  Wait.  This process is time consuming.
8.  Restart the daemons (ie 'net start crmdmgtd')
9.  Wait 20 minutes before logging back on to LMS
ngoldwat
Level 4
Level 4
Michel Hegeraat
Level 7
Level 7
I saw this once where a customer added a poller for all ports on all devices.
Did you add a poller?
Cheers,
Michel
Hi Michel,
No poller was added recently.
s.leyer
Hi ngoldwat,
The procedure worked fine. I have again a slim upm.db without losing data.
Thanks for your help.
Silvia
