LMS 4.1 won't launch after installation
kmong
I have installed lms 4.1 on a windows 2008 server however after installation, the webgui cant be launched
Nael Mohammad
Level 5
Level 5
What is the exact error you are getting?
Can you post the install logs from the root directory such C:\ or /var/tmp directory?
Karim.elwardany
go to RUN>>>services.msc
and check APACHE service is started, and if not started . start it
