LMS 4.2.3 and ASA SNMP v3 not working
tsadmin
I have ASA running version 8.2.5 and using snmp v3 as below;
snmp-server group Authentication&Encryption v3 priv
snmp-server user SNMP_TEST Authentication&Encryption v3 encrypted auth md5 cisco123 priv aes 128 password123
snmp-server host IN 10.10.10.110 version 3 SNMP_TEST
LMS device credential is as per above SNMPv3 config
Can't get this to work. Digging aroung but no avail. Any help is appreciated. I also try this on ASA 9.1 but same result.
This is my LAB environment.
Thanks. TS-Support
tsadmin
Update:
SNMPWALK using snmp v3, it works fine but chassisview below is the error;
Ip updated all the products using psucli and was successful.
Error
Message
Cannot find applicable device package for  10.10.10.15.
This error could be due to one of the following:
- The device  package for this device type is not installed.
- Device support for this  device type is not available.
- You are trying to open a component inside a  device.
To correct the problem, either install a device package for the  device type, or open the parent device to manage the component.
So how do you establish that 'it doesn't work' ?
Do none of the applications work?
Did you export the devices from the DCR to a csv file, so you can see and therefore validate the credentials?
Also something to know:  SNMP v3 indicates failed in the credential verification report, when it can't write to the device
cheers,
Michel
Thank you for your reply.
I can manually poll using SNMP v3 with the credentials (user, auth and priv).
I have other devices switches and routers also using SNMPv3 and was able to see the device using chassisview.
Since this is a LAB environment for now, I manually added each of these devices. See below; (ASA-VPN) is the device in question. Already tried increasing snmp timeout to 30 secs still no luck.
As you said I try to export using CSV and was successful;
10.10.1.50,10.10.1.50,,,10.10.1.50,1.3.6.1.4.1.9.1.950,0,281231715,CheckThisForSnmpset,,,,SNMP_TEST,cisco123,MD5,password123,AES128,80:0:0:9:3:0:c:85:25:1d:e2:1,,,,,,,,,,,,,,,,
10.10.10.254,10.10.10.254,,,10.10.10.254,1.3.6.1.4.1.9.1.576,0,279120799,,,,,SNMP_TEST,cisco123,MD5,password123,AES128,80:0:0:9:3:0:10:8c:cf:e6:f4:f8,,,,,,,,,,,,,,,,
10.10.100.88,vWLC,,,vWLC,1.3.6.1.4.1.9.1.1631,0,UNKNOWN,,,cisco321,cisco123,,,,,,,,,cisco,!NeverSl33p#,!NeverSl33p#,,,,,,,,,,,
10.10.10.15,ASA-VPN,,,ASA-VPN,1.3.6.1.4.1.9.1.669,0,999990413,,,cisco123,cisco123,SNMP_TEST,cisco123,MD5,password123,AES128,,,,cisco,cisco,cisco,,,,,,,,,,,
;End of CSV file
Thanks.
tsadmin
