LMS 4.2.3 baseline compliance template and standard ACL
ww9rivers
When using a baseline compliance template to check and deploy a standard ACL, I encountered what seems to be a bug:
I configured a template with these commands:
+ip access-list standard 21
+; Hosts allowed access
+  permit host 10.20.30.40
+  permit host 40.30.20.10
+  deny any log
When I do compliance check and deployment, the last line is dropped by LMS.
In fact, when I look into the job's "Work Order", the commands are:
After the job run, "show running-config" shows the access list matching the "Work Order" (without the "deny any log" command.)
Is this a bug?
Vinod Arya
Doesnt have any issues on my Lab 4.2.4. following is the Job Work order :
Name:Archive Mgmt Job Work Order
Summary:General Info
JobId: 2704
Owner: admin
Description: test_acl
Schedule Type: Immediate
Job Type: Compliance Check
Baseline Template Name: test_acl
Attachment Option: Disabled
Report Type: NA
Job Policies
E-mail Notification: Not Applicable
Job Based Password: Disabled
Device Details
DeviceCommands
Sup_2T_6500  ip access-list standard 21
  deny any log
10.104.149.180  ip access-list standard 21
  deny any log
Check your template, or export it and share, i will try it on my LMS server. also, check the same complaince job on other devices if you have such issues.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
