03-05-2014 01:59 AM
Can some one please advise.
I am have an issue with LMS where it is not fully comming up. I have shut down and restarted several times, with the latest giving me the following result within the macuhic.log, attached also PDSHOW :
Informational: Starting Cisco Process Manager communication thread
log4j:WARN No appenders could be found for logger (org.apache.activemq.transport.WireFormatNegotiator).
log4j:WARN Please initialize the log4j system properly.
CtrlPlaneListener -- Waiting to receive messages! Topic --> ut.uhic.mac
Intializing the Controler 1 = log Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.LogCtrl
messages will remian logged to file: macuhic.log
Intializing the Controler 2 = cblog Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.CBLogCtrl
Intializing the Controler 3 = gen Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.GenericCtrl
Intializing the Controler 4 = vqueue Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.VQCtrl
Intializing the Controler 5 = db Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.DBUpdateCtrl
Executing IDM Procedures
Failed to create Tables. Transaction Rolled back
: com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -110: Item 'getAuthenticatedUsers_ACS' already exists
Loading locationDetails jars
Setting Java path in windows
com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -110: Item 'locationDetails.jar' already exists
at com.sybase.jdbc2.tds.Tds.processEed(Tds.java:2884)
at com.sybase.jdbc2.tds.Tds.nextResult(Tds.java:2206)
at com.sybase.jdbc2.jdbc.ResultGetter.nextResult(ResultGetter.java:69)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:220)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:203)
at com.sybase.jdbc2.jdbc.SybStatement.updateLoop(SybStatement.java:1702)
at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:1685)
at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:431)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.medianetQuery(DBCtrl.java:100)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.initializeDBSchema(DBCtrl.java:78)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.init(DBCtrl.java:56)
at com.cisco.nm.cm.ut.uhic.mac.ctrls.DBUpdateCtrl.<init>(DBUpdateCtrl.java:53)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.initialize(EntityCtrlMgr.java:497)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.initControlers(EntityCtrlMgr.java:529)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.main(EntityCtrlMgr.java:898)
The number of DB connections:2
class com.cisco.nm.cm.ut.db.DBConnectionCreated new Database connection [hashCode = 10217370]
class com.cisco.nm.cm.ut.db.DBConnectionsuccessfully connected to db-url jdbc:odbc:cwsi
Creating Threads :8
Intializing the Controler 6 = filter Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.FilterCtrl
Intializing the Controler 7 = dec Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.DecodeCtrl
Intializing the Controler 8 = tpm Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.TPMCtrl
Created TPM
Intializing the Controler 9 = sktsend Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.SktSenderCtrl
Intializing the Controler 10 = skt Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.SocketCtrl
Started Socket Listener
class com.cisco.nm.cm.ut.db.DBConnectionClosed Database connection [hashCode = 10217370]
03-05-2014 02:07 AM
Hi Ian,
the CMFDATabase is down and other imp serveices are down.
try the belwo steps:
Run the below steps: 1)stop daemon manager, ( net stop crmdmgtd ) 2) Go to NMSROOT\CSCOpx\MDC\Apache\conf\SSL and delete all the server.* files. 3) run NMSROOT\CSCOPx\bin >perl.exe NMSROOT\CSCOpx\MDC\Apache\configSSL.pl -disable 4) wait for 2 to 3 minutes then run NMSROOT\CSCOpx\bin >perl.exe NMSROOT\CSCOPx\MDC\Apache\configSSL.pl -enable
Fill all the required details.
Note: Make sure you enter the correct HOSTNAME not FQDN.
5)start daemon manager (net start crmdmgtd )
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
03-05-2014 02:14 AM
Hi Afroz
Just want to check that I should continue, as I got the following :
D:\Cisco_Prime\bin>perl ..\MDC\Apache\configSSL.pl -disable
SSL is already disabled
Ian
03-05-2014 02:41 AM
Hi Afroz,
No joy, stil down !
Ian
03-05-2014 02:42 AM
Did you enabled it after removing the server.* files ?
if not kindly enable it ..
Thanks-
Afroz
03-05-2014 02:45 AM
please share the last 200 lines of syslog.log
Thanks-
Afroz
03-05-2014 02:59 AM
Culd I ask, what you are after as most of the Syslog entries are intenal syslog info.
Nothing to do with the system.
03-05-2014 03:10 AM
I was looking for the information on the process startup status.
Thanks-
Afroz
03-05-2014 03:46 AM
03-05-2014 03:22 AM
Hi Ian,
Share the below files in the meantime:
md.properties ( NMSROOT/CSCOpx/lib/classpath)
regdaemon.xml and ( NMSROOT/MDC/etc)
regdaemon.xml.bak
ctm_config.txt file from the below location:
NMSROOT/CSCOpx/MDC/tomcat/shared/lib and
/NMSROOT/MDC/tomcat/webapps/cwhp/WEB-INF/lib
Thanks-
Afroz
03-05-2014 03:51 AM
03-05-2014 05:34 AM
Hi Ian,
I have attached 2 files one for tomcat\shared\lib [ name of the file :: ctm_config(location shared)]
and other for /cwhp/WEB-INF/lib [name of the file :: ctm_config(location cwhp) ]
NOTE: change the NMSROOT in the above files according you you server.
stop the daemon manager
replaced the attached file
start the daemon manager
wait for 10-15 and check the status of the issue.
Thanks-
Afroz
03-05-2014 07:41 AM
No joy, still need not start
03-05-2014 08:03 AM
Hi Ian,
was it working before ?
when was the issue started ?
we need to look at the syslog.log to dignose the issue , if you thing it has some imp . info that should not be shared public ,you can remove it ,if possible.
try resetting the causer account >
NMSROOT/CSCOpx/setup/support>resetCasuser.exe
before that check and make sure the casuser is a part of administrator group.
Thanks-
Afroz
03-05-2014 08:24 AM
Hi Afroz,
You are going to be a bit surprised.
But the last state I now it was running well was back in Janurary 18th, so I think that is when the issue happened, a lot of the process logs go back to that date.. I only noticed just before I went on Holiday on the 14 Feb.
So have not had a chance to look into the issue.
I have come back to invesigate and found the issue was still in place.
So things like Syslog etc, wont contain any info on the issue.
At present I feel like something has corupted and so the system is dead !
