06-01-2014 08:37 PM
I have implement the LMS 4.2.4 few months back. I tried to setup the unreachable alert when some switch is down. I understand that the new LMS do not have the feature and it only can send out alert when reach some threshold.
I tried to click on the Fault > Threshold Settings and getting the below error message.
Cannot retrieve the list of groups from the grouping service.
Please check the PTMClient.log file for more details.
I have attached the log files. Anyone know how can I resolve it? Really completely out of idea.
Solved! Go to Solution.
06-06-2014 02:26 AM
You can download Windows, Solaris or Linux versions of LMS 4.2 from here and use them in case you have all the Hardware available.
http://software.cisco.com/download/type.html?mdfid=284259296&softwareid=280775102
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
06-02-2014 02:03 AM
your server has CTM errors as following :
27 May 2014|15:09:37.137|ERROR|PTMClient_Log|Thread-53|PTMOGSInteractor|getThresholdGroupFilter|.|CTMRequestProcessor::handleRequest() : java.lang.NoSuchMethodException 27 May 2014|15:09:37.139|ERROR|PTMClient_Log|Thread-53|PtmThresholdAction|perform|.| Exception occurred while applying OGS filterCTMRequestProcessor::handleRequest() : java.lang.NoSuchMethodException 27 May 2014|15:09:37.139|ERROR|PTMClient_Log|Thread-53|PtmThresholdAction|perform|.|java.lang.Exception: CTMRequestProcessor::handleRequest() : java.lang.NoSuchMethodException at com.cisco.nm.trx.ptm.ui.PTMOGSInteractor.getThresholdGroupFilter(PTMOGSInteractor.java:314)
It may be a corrupt DFM DB which may lead you to re-initialize your DFM DB, procedure here.
Mostly such CTM errors are sometime due to some port clash or resource crunch, try to remove/disable any unwanted third part software, specially Antivirus and Active scan for sometime and reboot your server to see it goes away.
06-02-2014 02:06 AM
Hi Vinod,
I have done few times of DB re-initialize but no luck. It is on Solaris VM platforms.
06-02-2014 06:32 AM
Has it worked ever? I have seen similar issues 3-4 times and unfortunately majority of them had software issues which were fixed only after re-install.
Which version of LMS are you using?
-Thanks
Vinod
06-04-2014 12:52 AM
Yes, it worked but the problem will come back again.
I am using LMS 4.2.4 Solaris. Can I convert it to Windows version?
06-06-2014 01:07 AM
Unfortunately there is no convert option from Solaris to Windows. Cross platform restore is supported only from Solaris/Window to Soft Appliance.
So a backup taken on Solaris won't restore on Windows machine and vice-versa.
Either we have to start afresh on windows or get the VM for LMS and install backup their.
-Thanks
Vinod
06-06-2014 01:25 AM
Hi Arya,
Thanks for the response. I only have the OVA supplied by Cisco and it is on Solaris platform. Is that mean if i can download the LMS windows installer, i can use back my copies on Windows?
06-06-2014 02:26 AM
-Thanks
Vinod
