ip flow problem
techguy
Level 7
Level 7
I am trying to fetch data on netflow analyzer 9 by Cisco router 2911. But netflow is unable to show any data. Kindly help
cr2911-01#sh runn | sec ip flow
ip flow-cache timeout active 1
ip flow-export version 5
ip flow-export destination 10.1.208.32 9996
interface GigabitEthernet0/0
description Connected to LAN
ip address 172.16.250.14 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip nat inside
ip virtual-reassembly in
ip policy route-map divert
duplex auto
speed auto
end
cr2911-01#sh runn | sec snmp
snmp-server community public RO
snmp-server community public RW
snmp-server ifindex persist
snmp-server location DXB-DC
snmp-server contact [email protected]
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M4.bin"
cr2911-01#sh debug
IP Flow:
  IP Flow cache allocation debugging is on
  IP Flow export mechanism debugging is on
cr2911-01#sh logg
Nov 10 13:09:05.006: IPFLOW: Error sending export packet: Enqueued to process level
Nov 10 13:09:07.006: IPFLOW: Sending UDP export pak 927581 to 10.1.208.32 port 9996
Nov 10 13:09:07.006: IPFLOW: Error sending export packet: Enqueued to process level
Nov 10 13:09:08.006: IPFLOW: Sending UDP export pak 927611 to 10.1.208.32 port 9996
Nov 10 13:09:08.006: IPFLOW: Error sending export packet: Enqueued to process level
Nov 10 13:09:09.006: IPFLOW: Sending UDP export pak 927641 to 10.1.208.32 port 9996
Nov 10 13:09:09.006: IPFLOW: Error sending export packet: Enqueued to process level
Nov 10 13:09:10.006: IPFLOW: Sending UDP export pak 927671 to 10.1.208.32 port 9996
Nov 10 13:09:10.006: IPFLOW: Error sending export packet: Enqueued to process level
XIE YAO
Level 5
Level 5
per cisco, http://www.cisco.com/en/US/docs/ios/12_2/switch/command/reference/xrfscmd5.html#wp1071616
0 export packets were sent up to process level
The packet could not be processed by CEF or by fast switching, possibly because another feature requires running on the packet.
Did you enable CEF?
yes ip cef is enabled
Try configuring ip route-cache cef for the interface.
