01-23-2014 03:50 AM
Hi guys,
our LMS server stop running after crash :/
I'm trying to run service manually:
net start cmrdmgtd
but it's only displaying error:
"The service is not responding to the control function."
Checked syslog.log and found dmgtd warning messages which are probably responsible for preventing process to start.
Jan 23 05:33:57 127.0.0.1 dmgtd: WARNING: System Memory (RAM) is less than Required Memory, which may affect performance
Jan 23 05:33:57 127.0.0.1 dmgtd: Required RAM space is 1 969 432 130M and System RAM space is 16384M
Jan 23 05:33:57 127.0.0.1 dmgtd: WARNING: System SWAP Memory is less than Required Swap Memory, which may affect performance
Jan 23 05:33:57 127.0.0.1 dmgtd: Required SWAP space is 2130 567 168M and System SWAP space is 32768M
Jan 23 05:33:57 127.0.0.1 dmgtd: WARNING: CPU Speed is less than Recommended
Jan 23 05:33:57 127.0.0.1 dmgtd: Recommended CPU speed is 1 398 035 032 ~MHz and System CPU speed is 2900 ~MHz
I don't have SuperComputer on site to meet those requirements
System specs:
Windows 2008 R2 64b
installed on VM
RAM: 16Gb of RAM
CPU: Xeon X567 2,9GHz
Is there a way to convince dmgtd to suggest lower, real life requirements?
What causing those high RAM and CPU values?
Solved! Go to Solution.
02-03-2014 03:55 AM
Hi Afroz,
I don't see attachement , could you please attach those files?
I still have some problems with few processes :/
02-03-2014 04:08 AM
02-03-2014 04:59 AM
Thanks a lot
