LMS 4.2 (Fault Management Module)
hook huang
Hi sir:
The LMS send mail alert to me , and the event is CPU High Utilization.
But the Current Utilization vaule is wrong.
How can I correct this problem?
EVENT ID                = 000M51T
TIME                    = Thu 06-Feb-2014 08:00:04 CST
STATUS                  = Active
SEVERITY                = Critical
MANAGED OBJECT          = 192.168.1.1
MANAGED OBJECT TYPE     = Security and VPN
EVENT DESCRIPTION       = HighUtilization::Component=PSR-10.10.127.64/1 [Chassis] [ASA 5505 Adaptive Security Appliance];ComponentClass=Processor;ComponentEventCode=1058;UtilizationThreshold=90;CurrentUtilization=3198607%;
NOTIFICATION ORIGINATOR = Fault Management Module
AFROJ AHMAD
Hi Hook,
what is the threshold configured ?
Can you try to increase the Threshold and check how it works.
I have attached the Image for the same
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
5 Replies 5
AFROJ AHMAD
Hi Hook,
Thanks-
Afroz
Hi sir:
The cpu utilization value should be between 1 to 100.
According to the message, the htreshold is 90% , but LMS detect the CurrentUtilization=3198607.
Kindly share  your server threshold settings..
Thanks-
Afroz
Hi sir:
Thanks for your reply.
Is there another way to check why it detect wrong value ?
Hi Hook,
It could be a false alarm , you can try delete and re-add the device in DFM alone.
1.3.6.1.4.1.9.9.109.1.1.1.1.3.1  , you can do a direct SNMP WALK on this OID and see what
values you get.
Thanks-
Afroz
