02-16-2014 11:57 PM
i have trying to install LMS 4.2 in Windows Server 2012 standerd edition, but at the time of installation it showing the error
** Cisco Prime LAN Management Solution 4.2 installer found that you are currently running Windows 2008 in 32 bit-mode, which is not a supported platform. Cisco Prime LAN Management Solution 4.2 supports Windows 2008 Standard and Enterprise Editions (64 bit) , and Windows 2008 R2 Standard and Enterprise Editions.
Refer to Cisco Prime LAN Management Solution 4.2 Installation Guide for more details on the supported platforms."
see the mentioned screenshots
so please suggest me what i will do ?
Debu
02-17-2014 12:28 AM
Any one please suggest me...
Debu
02-17-2014 01:33 AM
PLEASE ANYBODY CAN HELP........... PLEASE
Debu
02-17-2014 01:55 AM
Hi.
please no one is here to help me ??????????
Debu
02-17-2014 02:35 AM
Please help me............
Debu
02-17-2014 02:55 AM
strange.!!!!!!!!!!!!!
no one facing this problems ?
Debu
02-17-2014 03:03 AM
Debu,
The people who respond to your posts are VOLUNTEERS (including Cisco staff).
They do not have any obligations to drop whatever more import things they are doing just to respond to other people's posts or threads.
If you need immediate assistance, I'd recommend you create a TAC Case.
02-17-2014 06:35 AM
02-17-2014 07:52 AM
If you contact the TAC, they will most likely advise you to install the software onto a supported platform.
Windows Server 2012 is not supported at this time.
02-17-2014 10:05 AM
May be a bitter experience, but unfortunately, CSC is a self-driven community by individual contribution. So there's no SLA for any response.
Most of the time, contributors are active and hence response's are there, but sometime there's delay. Any proactive support requires our customer's to contact TAC, as Marvin said, which works 24x7.
You problem will not be supported anywhere though, as the platform isn't tested and supported. Even somehow if you bypass and install, you may experience a chain of problems one after other in future. Which may always fetch same answer as solution to get it installed on Supported platfom.
-Thanks
Vinod
