03-14-2014 01:08 PM
Hello Friends
My company asked me to give a knowledge transfer session for a customer. I have less experience in LMS 4.2.
Does anyone have any video, presentation or document ?
Thanks and Regards,
Abdul Hameed.
Solved! Go to Solution.
03-14-2014 05:20 PM
Hi Abdul,
Use this link:
http://www.cisco.com/c/en/us/support/cloud-systems-management/prime-lan-management-solution/products-user-guide-list.html
these user guides links will take time for you understand and deliver the same.
one more thing I can suggest you :
I hope you have LMS 4.2 already installed . login to it and there you will find and option on the right hand side name as " HELP".
if you browse to let say admin > debug settings and then click on "HELP" . you will go to know what are different debug settings are why they are used.. similarly you can do the same for others by navigating to different links and clicking on "help".
Thanks-
Afroz
****Ratings Encourages Contributors ***
03-14-2014 03:42 PM
If you don't have any experience why did the company assign you to provide "knowledge transfer"? And besides, you giving the client video presentation and/or documentation in place of a "knowledge transfer" doesn't bode well.
03-14-2014 05:20 PM
Hi Abdul,
Use this link:
Thanks-
Afroz
03-15-2014 12:49 AM
Hello Afraj
Thanks for your kind help.
Abdul Hameed
