LMS 4.2 upgrade to LMS 4.2.1
fender100
Hello Support,
I just want to upgrade LMS 4.2 to LMS 4.2.1. I need a new license after de upgrade of LMS 4.2.1? or I can keep the same license of LMS 4.2.
thanks!
Luis Ortega
Vinod Arya
LMS 4.2.1 is just a minor patch upgrade to LMS 4.2 and does not requires a new license.
The existing license should work.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks for the Infomation and support on this!!!
Pleasure it helped! You may close this thread if you think the query has been answered.
For more details on this please check LMS 4.2.1 Release note :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2.1/readme/lms_421_readme.html#wp1170881
-Thanks
Vinod
