Hi Lothar,
AFAIk, database restore can be possible Only to LMS 4.2 from 3.2 , you can restore directly to 4.2.5
You need to restore the backup on 4.2 first and then proceed with upgrade.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/install/guide/install/dmg.html#17503
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
