LMS 4.x - DFM - how to disable certain traps beeing displayed in Fault Monitor?
hgans
hello,
there are always some Traps more or less processed by LMS showing up in Fault Monitor View.
Especially some Pass-Through or Unidentified Traps can be annoying if you want to keep the view clean...
I wonder how to disable such Traps to not beeing displayd on the DFM Fault Monitor View?
Thanks to helpers
Herwig
Michel Hegeraat
Level 7
Level 7
Not possible, you can only disable the trap listener of DFM.
Only on the notification groups you can filter certain alerts but not in the view.
Cheers,
Michel
