LMS - Add Discovered Devices to a Group
Ibrahim Jamil
Level 6
Level 6
Hi Netpro
i have created 5 UDG (Ex CampusA - to- CampusE and five different discovery jobs based on the user defined group,
Also i have created a discovery job and added to the UDG CampusA  ( Subnet 172.16.16.0) in order to see only devices in campusA , but the LMS Discover  all our devices in the organasations!!!!
what rong i have done to let LMS  sees all Devices
thanks
jamil
Michel Hegeraat
Level 7
Level 7
Did you create an ip range include filter in each job? Or how did you limit the discovery?
Cheers,
Michel
Hi Michel
can you tell me how to do it?or point me out to some Docs
jamil
I hope you see the filter on the UDG determents what devices are in that group.
It is not the discovery job that puts the devices in a UDG.
Although you can place the newly discovered devices in a group in 4.1 or higher but after the next discovery this changes.
You can have multiple discoveries for different subnets. You can when you create the discovery job tell it to filter on an IP range.
The steps of the discovery are modules, community string(s), filter and global settings.
In the filter part you can say what to include or exclude and so limit the discovery to that range..
Cheers,
Michel
