inventory management problem with WS-C2950-24 on CWLMS 4.0
Hi Joe,
I have a problem with inventory management wiht 2950- 24 switches on which I am not able to capture inventory as well as the configurations. The IOS version is 121-22.EA13 and featureset is i6k2l2q4-mz. However, when I troubleshoot it, all the transport protocols (Telnet, ssh, tftp etc) shows success.
Best Regards // Rajiv
Vinod Arya
Inventory uses snmp to communicate to device. Please check you device has snmp configured and LMS has correct SNMP RO credentials added to it.
Please try to do a manual snmpwalk from LMS server (using device centre > tools) and see the walk succeeds.
Then again try to run the inventory from LMS server on this perticular device and if it fails, share the failure result/screenshot etc details. NMSROOT/log/ic_server.log as well.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
