LMS and CSCsx09107 patch
j-fragoso
I want to intall CSCsx09107 patch, as prerequisite is necessary to install open ssl but the url doesn't work
Prerequisites
Before installing this patch on Common Services 3.0.5, 3.0.6, 3.1, and 3.1.1, you must install OpenSSL 0.9.71 Security Vulnerability patch.
The OpenSSL 0.9.71 Security Vulnerability patch is available at:
http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des
Where can I find this patch?
6 Replies 6
Hello mermel,
I already have CSCsx09107 patch but previosly is necessary to intall OpenSSL 0.9.71 Security Vulnerability patch which I don't find
Sorry, I didn't read your post carefully. Which version and platform of LMS do you have ?
We have LMS 2.6 (CS 3.0.6) under Windows
the patch name is cwcs-win-CSCsk70765-K9.zip
you find it for CS 3.1.1 (but it is applicable for CS 3.0.6 also)
try this link
http://www.cisco.com/cisco/software/release.html?mdfid=278788769&flowid=5147&os=Windows&softwareid=280804892&release=3.1.1&rellifecycle=&relind=AVAILABLE&reltype=all
Thanks mermel
