LMS and MS update
georgeef1
How can we determine which windows patches and update can effect ciscoworks.
Is there any information released by cisco on this.
For eg, if I want to check if the following MS updates will affect the LMS or not ;
ie7-Windowsserver2003-KB961260-x86-ENU.exe
Windowsserver2003-KB923561-x86-ENU.exe
Windowsserver2003-KB952004-x86-ENU.exe
Please suggest.
-Thanks
Joe Clarke
We don't track all MS updates. Typically, we say that any hotfix will be supported. If problems are encountered, we record them as bugs, and work with Microsoft if need be to get the issue resolved. There are no known issues with these fixes.
Joe Clarke
