LMS Authentication Failure
bgl-group
This was working up until last week but now when I try to log into LMS I just get an authentication failure message.
LMS is configured to use ACS for access but ACS is not writing any information in the log files for the LMS server. So I can only assume that there is a problem with the link to ACS
How can I gain access to LMS and allow me to switch the system to a non-acs mode so I can access the server without first having logged in?
Joe Clarke
From the CLI, run the command:
NMSROOT/bin/perl NMSROOT/bin/ResetLoginModule.pl
You will then be able to login using local authentication and authorization.
Joe Clarke
