LMS can not display image switch 4507R + E
Roni Apaza
I installed LMS 4.0 succesfully, but  when i go to topology, can view all network, but the "AswitchA" Core 4507R+E be displayed as "?"
, and it can not display this "AswitchA" into CISCO VIEW, display this messaje :
"Cannot find applicable device package for ...
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component."
Please do they know a solution? Its very important
AFROJ AHMAD
1.3.6.1.4.1.9.1.1286 >> This must be the sysobjectID of the Device . Please check
if yes, kindly check the device supported list of LMS 4.0 ,it say's this device is upported only for [Inventory Config and Image Management]
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/device_support/table/lms40sdt.html
I hope this answer your query.
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Afroj
thanks. Afroj
I see which my supervisor "Sup7-E" do not displayed into link.
Understand my supervisor not is supported.
