LMS Certificate Installation
adm-hzwez
Hello All,
I'm new to the forums and was wondering if i could get some help. Our department is runing CiscoWorks LMS 4.0 and we have a remediation project going on that all network appliances need to have https either disabled or a certificate installed so that it works with our companys CA. I was wondering if anyone else has installed any Root or Intermediary certificates and how to make an SSL certificate request so I can generate a certificate request from the CA.
Any help with this would be apprechiated.
srkala
Procedure to regenerate SSL certificate is as follows :
1. Stop the daemon manager
Windows- net stop crmdmgtd Solaris/linux - /etc/init.d/dmgtd stop
2. Regenerate the SSL certificate (Dont forget to start you shell/command prompt session as Administrator):
     *Remove server.*  files under NMSROOT\MDC\Apache\conf\ssl (take backup of all 4 files in some other directory before deleting).
     *NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -disable
     *NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -enable
     *Fill all the details it request for.
     *Ensure that the following files are created under NMSROOT\MDC\Apache\conf\ssl :
server.crt
server.csr
server.key
server.pk8
3. Start the daemon manager
Windows- net start crmdmgtd Solaris/linux - /etc/init.d/dmgtd start
Then give it about 15-20 minutes for all services to come back up before logging in to the LMS.
