08-25-2010 01:29 AM
Netpro's can you help ?
I'm running LMS 3.2 on Windows 2003 Server.
When navigating to Common Services -> Device and Credentials -> Device Discovery -> Discovery Settings I'm getting a HTTP Status 500 error on the page.
I have been through CSCsq63152 in order to try and rectify this but no success.
Any comments would be greatly received !
Lee
08-25-2010 03:52 AM
Please update your current MDF version and pdshow output and is possible the screenshot of the error message. Do let us know the current version of the modules of LMS 3.2.
podhillo
08-25-2010 07:57 AM
10-15-2010 07:05 AM
Hi - Have you managed to resolve this problem? I am having exactly the same
issue....
Rod
10-15-2010 07:21 AM
Most likely the NMSRoot/conf/csdiscovery/CSDiscovery-config.xml is corrupted. The file you have on your server is it a valid xml document?
