LMS. Discrepancies between home page and jobs in RME
j-fragoso
I have noticed there are some discrepancies regarding the information showed by home page and rme jobs.For instance, home page shows 192.168.151.112  device as failed but when I go to rme job this device is not showed. Addition this device isn't added to rme database so I don't understand why this device appears here and I don't understand why home page shows 1 device failed and rme job shows 0 device failed.
Any idea?
(I attach some screenshots)
Nael Mohammad
Level 5
Level 5
Any time an archive job completes with a status other than Successful, it will report as failed. Partially Successful devices will be identify as a failed device even though it was able to get the startup/running config and not the vlan information.  Since the vlan info is the problem, you need to ensure that telnet or ssh is configured for that device.
Since you are saying this device does not belong in inventory, go RME --> Devices --> Device Management --> Normal Devices and delete it.  Check under alias devices if its showing up as something else.
Goto Common Services --> Device Management --> Device and Credentials and delete the device from there.
The 192.168.151.112 device doens't exist to any BD (CS, RME etc...)  so I don't understand why the home page shows this device as failed. Can I delete this failed?
anybody knows how I could deleted this Failed (view attach)?
