08-21-2007 12:55 PM
I am having a issue with LMS. I recieve this error when I go to netconfig.
URN_NOT_FOUND : urn "JRM" : Not found
This happens when I go to look at the jobs I have already created in netconfig. I am not able to view those jobs although they do still run as it the jobs set to reboot my routers still work.
Dave
08-23-2007 08:50 AM
08-23-2007 08:55 AM
If you execute:
pdexec jrm
Does the jrm process come up? That is, if after running the pdexec command, run the command "pdshow jrm". What is the output?
08-23-2007 09:57 AM
Yes it states it is running normally
08-23-2007 10:08 AM
Good, this may have just been a transient error, then. Restart dmgtd from the command line:
net stop crmdmgtd
net start crmdmgtd
You should be up and running. If you still have problems, one thing that could cause processes not to initialize property is a server that does not meet minimum requirements. Given the apps you have installed, your server must have at least two physical CPUs (or cores) and have at least 2 GB of memory with 4 GB of page file.
08-23-2007 10:28 AM
Nope, I get the same error after restarting them ?
08-23-2007 10:29 AM
So what are the hardware stats on your server?
08-23-2007 10:53 AM
2.8 gig xeon and 1 gig of RAM
08-23-2007 10:57 AM
That's the problem. You do not have enough memory to start LMS. You need to add another 1 GB of physical RAM just to get the suite of applications to start.
08-23-2007 11:02 AM
hmmm... I have been using this suite for 3 years now. I wonder why it would have the problem now? Could it have been struggling along and then just not had enaugh to do it anymore?
08-23-2007 11:04 AM
I know for a fact that entire bundle (LMS 2.5 and higher) cannot start on 1 GB of RAM. It must have 2 GB with 4 GB of backing swap. Without this, processes will fail. These requirements were not as high under LMS 2.2 which could explain how you were running LMS successfully for so long.
08-23-2007 11:24 AM
I have some RAM here that I am tring to work.
I will respond as soon as I do. That makes perfect sense about being on 2.5 and up.
Dave Peter
08-23-2007 11:38 AM
08-23-2007 11:53 AM
Send the output of "set" from a DOS command prompt as well as the C:\progra~1\cscopx\MDC\etc\regdaemon.xml file and the current jrm.log. Note: if the data in regdaemon.xml is too sensitive to post, open a TAC service request, and include all of this information.
08-23-2007 12:30 PM
08-23-2007 12:59 PM
Wow you are not going to believe this. I went through all the JRM files XML and html and some other ones. I just opened them and read them to see what they did. Then I went back and logged into Cisco Works and went to the netconfig jobs and netshow jobs and everything works! Not sure what happened? I made it recognize the files again after I opened them?
Dave
