lms-Explaination
Ibrahim Jamil
Level 6
Level 6
i m looking for explanation related to attached diagrams
thanks
jamil
Vinod Arya
Seems you are trying to make a group and no device seems to be matching the criteria to be a part of that group.
In Screenshot 1 there is a mistake, that whatever rules you want to make, you need to click Add Rule Expression for that to be added, unless which it is useless.
For more details on managing/ administering group and grouping policies, please check the user guide section :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/admin/groups.html#wp1091825
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
