Unable to poll SNMP data from Nexus 7010
fasih2012
Level 5
Level 5
I have two Nexus 7010 in the data center. I'm unable to poll SNMP data from one of the NEXUS 7010s. The other Nexus 7010 is working fine.  I have compared the SNMP configurations, and they are identical. When I do "show snmp" on the non-working switch, I have SNMP packets in "Unknown Context name", not sure why. I have done show vdc and it matches the working switch output.
Here is output of show snmp from the non-working switch:
133 SNMP packets input
        0 Bad SNMP versions
        0 Unknown community name
        0 Illegal operation for community name supplied
        0 Encoding errors
        0 Number of requested variables
        0 Number of altered variables
        0 Get-request PDUs
        0 Get-next PDUs
        0 Set-request PDUs
        0 No such name PDU
        0 Bad value PDU
        0 Read Only PDU
        0 General errors
        0 Get Responses
        133 Unknown Context name
0 SNMP packets output
        0 Trap PDU
        0 Too big errors
        0 No such name errors
        0 Bad values errors
        0 General errors
        0 Get Requests
        0 Get Next Requests
        0 Set Requests
        0 Get Responses
        0 Silent drops
Community            Group / Access      context    acl_filter
xxxxxxxxxx          network-admin       v.e
yyyyyy              network-operator    v.e
______________________________________________________________
                  SNMP USERS
User                          Auth  Priv(enforce) Groups
____                          ____  _____________ ______
josh                          md5   des(no)       network-admin
admin                         md5   des(no)       network-admin
carol                         md5   des(no)       network-admin
fasih                         md5   des(no)       network-admin
NOTIFICATION TARGET USERS (configured  for sending V3 Inform)
User                          Auth  Priv
____                          ____  ____
SNMP Tcp Authentication Flag : Enabled.
Port Monitor : enabled
Policy Name  : default
Admin status : Not Active
Oper status  : Not Active
Port type    : All Ports
Counter          Threshold  Interval Rising Threshold event Falling Threshold  event In Use
Link Loss        Delta      60       5                4     1                  4     Yes
Sync Loss        Delta      60       5                4     1                  4     Yes
Protocol Error   Delta      60       1                4     0                  4     Yes
Signal Loss      Delta      60       5                4     1                  4     Yes
Invalid Words    Delta      60       1                4     0                  4     Yes
Invalid CRC's    Delta      60       5                4     1                  4     Yes
RX Performance   Delta      60       2147483648       4     524288000          4     Yes
TX Performance   Delta      60       2147483648       4     524288000          4     Yes
SNMP protocol : Enabled
ted.schwind
Did you ever get this resolved? We have a pair of 7010s that were working just fine with snmpv3 and then one of them stopped authenticating. I have stripped the snmp configs and reapplied to no avail.
ted.schwind
Found the cause. The snmp process crashed on the N7K.
What is the fix for it?  I was thinking to upgrade to the latest release.
dknoezinger
This issue is pretty likely caused by a Bug existing in NX-OS 4.x and 5.x: CSCti07871
A workaround is to completely remove the SNMP community configuration and reapply only the necessary part.
Daniel
