LMS http
xshant
Level 3
Level 3
Dear *,
LMS 3.2 uses port number 1741 to access the CiscoWorks Server in normal (HTTP) mode and port
number 443 to access the server in secure (HTTPS) mode by default. Is there anyway to disable http and just use HTTPS?
Aamir
vergeerf
Level 5
Level 5
Yes, go to http://servername:1741/cwhp/classic.SSL.do -> apply
then restart the deamon manager:
net stop crmdmgtd
net start crmdmgtd
