LMS migration issue
cmartinvalle
when migrating LMS from 2.6 to 3.0 (local migration), is it necessary to update the license or the installation detects automatically the old license installed in the 2.6 version?
Many thanks.
m.sir
Level 7
Level 7
Check following (steps 3 and 4)
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/install/guide/instl.html#wp1395436
You need license key for upgrade but you can use 90 days trial
Hope that helps rate if it does
M.
thank you very much.
The matter is that we have a license for an unlimited number of devices and it's installed in the LMS 2.6
When we upgrade to the 3.0, is that a valid license or do we have to upgrade this license too?
Regards.
