LMS question
ggittins
Level 2
Level 2
Is there a report i can run on LMS to see what ports are set on error disable?
and if there is can i send another script
to unset them
yjdabear
For the first part, it can be found either on the CM tab of the LMS portal in the Discrepancies pane under "Port is in Error Disabled State", or generate it on-the-fly via Campus Manager - Reports - Report Generator - Campus Manager Reports + Discrepancies - Available Types: Port is in Error Disabled State.
