LMS removing Subnet
georgeef1
How do I excluce a 10.254.2.0 subnet from a user tracking ping sweep (LMS 3.1).
I was unable to exclude as the subnet is not listed.
Which subnet does LMS automatically shows over there?
-Thanks
Joe Clarke
UT will ping all of the subnets listed in the NMSROOT/campus/etc/cwsi/RouterData.xml file. If a router with that subnet has not been Data Collected, then ping sweep will skip it.
Thanks Jclarke,
So is there a way to remove a specific subnet or exclude sort or setting in LMS either via GUI or any file modification.
-Thanks
To exclude a subnet which has been found by Campus, go to Campus Manager > Admin > User Tracking > Acquisition > Ping Sweep. If the subnet isn't showing there, then Campus hasn't found it, and it won't be pinged anyway.
