LMS & Solaris IPMP
yjdabear
It appears as long as LMS is bound to the one single floating virtual IP addr in gatekeeper.cfg, it should work. Nonetheless I'm wondering if there's any caveat. Does LMS play nice with IPMP's outbound load spreading feature, if at all?
19 Replies 19
A service request would need to be opened requesting such a patch.
I'm not following: Do you mean a "service request" (as in a TAC case???) in order to have a patch produced for 3.1, or simply to obtain the patch?
A TAC service request would need to be created requesting the patch for 3.1. This is how the 3.0.1 was built.
Got it, will do. I assume this is because the bug was filed only against 3.0.1. Do I need concrete evidence (such as a live 3.1 install) to prove the need of a patch?
If you want, as this way you can validate the patch. However, it's not required.
