LMS taking loopback IP from devices
sachipanda
Community Member
I am facing a problem with device discovery.It shows the loopback IP address of the devices instead i want to see the management IPs.Can anyone give a solution for this asap.
yjdabear
Do you have "Use LoopBack Address" checked under CM -> Admin -> Device Discovery -> Discovery Settings -> Preferred Management IP? If so, uncheck that and look again after the next discovery cycle.
it is exactly what yjdabear wrote
and for devices being already discoverd you could change the Management IP in Campus Manager - Topology Services. Open a Network View, highlight a device and use the advanced menu (right mouse click) and go to 'Change Management IP...'
Thanks buddy
This was the case.I unchecked it & it worked
